Quote Originally Posted by WRCPUG View Post
Marshy- not sure if you do your valve checks yourself but do you know if you have to drop the motor to get easy access to the heads? Or just remove airbox and throttle bodies??
Occasionally I do them, but I've always got motors being dropped out and put back in for various reasons (frame replacement being the most common). Dropping the motor on an Ape is surprisingly easy. But I'd say at a guess that you could access them in situ, even though the front bank is a little harder to access.
