I think I ran 17 43, so with my chain length ended up being almost as short as you can get in with the rear axle adjustment, could run 16 40 for a similar gearing but longer wheelbase quite easily I suppose. I'm not sure about what height I have set on the rear shock but front is slightly lowered maybe 10mm. Linkage and triples all standard. Ill get some measurements later in the week as I'll be pulling the shock out soon.
