Results 1 to 5 of 5
Thread: R6 Fork Oil Change & Seal Replacement
    Have leaky fork on 2008 R6, thought I would try to fix.
    So many questions!
    Any suggestions on the height of the oil? Manual says 103mm. I am using 7W.
    Thanks.
    http://www.ebay.com.au/itm/like/2908...s=true&viphx=1
    I have used these on the MX bikes and the race bikes before... Depends on how and why the seal is leaking, if it is just a small piece of dirt in there, as long as the seal is still good this will fix it.
    Otherwise its forks out and apart to fit new
    Quote Originally Posted by Stu23 View Post
    Me too (used the seal mate thingies). Sometimes they work, sometimes not. The hard part is getting all the way around.
    I usually run 110mm air gap on the R6. I use 5w oil.
    Thanks. I tried the seal mate, but it still kept leaking.
    Thought it was time I tried to do oil and seal change myself! Finished the leaky one off last night, will try and setup the other tonight to be setup the same.
    There was a great Dave Moss video from OTT specifically for the 2008+ R6 forks, (cost USD$5 online). [Marshy you should do some how to videos and YT them pointing to the TT site for more info].
    He recommended 130mm (track and street compromise) and didn't mention fork oil weight, I assume more air gap makes the forks softer?
    you can play around with the air gap to make the fork feel a little softer or even harder depending
