The chain tenisoner you will never fix. Its just noisy, dont worry about it.
Old engine is conrods, valves, springs. They are the failure bits
thanks Kris. I know the 09 had some problem with the conrods failing but wasn't that the first batch that was then covered under warranty? Or is that an ongoing issue not related to the faulty batch?
