Results 1 to 1 of 1
Thread: 2014 YZF-R6 Race Bike
    [SOLD] 2014 YZF-R6 Race Bike
    {SOLD}2014 YZF-R6 Race Bike (08) frame
    Lovingly built from the ground up between March and June 2014.
    Some of you know this bike. You can research the build thread here....
    http://www.tarmactalk.com/forum/show...-Build-Finally
    This bike was completely stripped and sent to Laurie Alderton for straightening
    All bearings were replaced and every component painstakingly inspected and cleaned as new.
    The engine was methodically rebuilt from scratch by Ian Irving from YRD.
    Higher compression, cam timing, YEC Parts.
    Everything is carefully lock wired and still in fantastic condition.
    This bike has seen less than 10 (slow) days on track since completion.
    Someone should RACE this. I’ve not the time. It’s a weapon.
    Offers around $11k. PM me for further info
    Engine/ Fuelling
    YEC Clutch kit and springs
    Woodcraft engine cases with Stainless steel skid pads
    GB Racing engine covers
    Driven Block off plates
    BMC Air Filter
    Dynojet PCV and SFM with all 8 injectors carefully mapped
    Powertech BSB Velocity stacks, optimised at 13,200rpm.
    2014 YEC ECU and YEC wiring Harness
    Akrapovic Racing line stainless headers and titanium canister
    MAC Radiators Add-on Racing Radiator
    Samco Race Hose kit
    Shorai Lithium battery- Rock solid.
    Frame
    2008 stat. Frame
    DB Holders Lightweight Subframe
    Motoholders Race Fairing Stay
    Vortex V3 Rearsets
    Graves R6 Diamond Frame sliders
    Custom Race seat with Graves seat foam and Sergeants quick release pins
    Fast Frank Racing captive rear caliper bracket and axle guide
    Fast Frank Racing GP stand lifters
    Woodcraft shark guard
    Bodywork / Suspension / Wheels
    Ohlins NIX 30 Carts with Zenodamper internals
    Ohlins TTX Shock with Zenodamper internals
    Ohlins SD020 Steering Damper kit
    Racers Edge fairings, vinyl wrapped in Matte Metallic Blue
    Wet4u Racing Carbon / Kevlar tank protectors
    Carbon Fibre front and rear fenders, sprocket cover, mounting brackets.
    Sandblasted and powder coated wheels with Fast Frank Captive spacers
    RK GXW Chain - Driven sprocket kit 45/15.
    Titanium- axle nut, fork pinch bolts, triple clamp pinch bolts, top yoke bolts, rotor bolts
    Electronics / Controls
    Race Technology Dash 2 w’ lap timing on Carbon fibre mount.
    Race Technology DL1 data Logger inc. 20Hz GPS
    Handlebar controls for YEC Map / Lap Marker / Pit Limiter
    Dash inputs for Power Commander / YEC software
    Dash controls for fans / Data Logger / Engine Run
    Lightweight Starter switch block.
    Riderlogic Custom wiring harness with inputs for Brake Pressure and suspension sensors
    Pazzo Levers / Active Evo throttle kit / Graves Brake lever guard.
    Translogic quick shifter
    Brakes
    Brembo RCS19 Master cylinder
    Brembo Monobloc M4108 Calipers with tapered spacers
    Braking SK2 directional front wave rotors
    Braking lightweight rear rotor
    Galfer Racing Lines, front and rear.
    Spares
    Yes…..
    IMG_1195.jpgIMG_1186.jpgIMG_1187.jpgIMG_1188.jpgIMG_1189.jpgIMG_1193.jpgIMG_1198.jpgIMG_1199.jpgIMG_1202.jpgIMG_3387.jpgIMG_3397.jpg
