As a member of many forums I seen this technique on how to install Frame sliders to your beloved fairings that require you to drill.
In a nut shell you..Set the bike on a rear stand, take the fairings off and point a laser level/pen at the center of the bolt which will be used as the attachment point for your slider. Then re-install the fairings and now you have a center mark from the laser as your drilling point”.
The only thing I brought was the laser pointer (other than sliders) as I already had a dremel and car stands.
http://www.ebay.com.au/itm/LED-Mini-...item5d3cc7fd1a
Uploaded with ImageShack.us
I then attached laser pointer to car stand, I’m guessing you can use chair or something that won’t move.
Once I placed the laser pointer in the correct location I then re-installed the fairings and used the laser as my first point to drill.
After a few hours work
