Andrew,
the closer I look, the more I work out... now that I worked out what it is ( Mr Ed. )....
assuming your clip ons are below your trees....What is your fork diameter below your clip on? (need to go below the taper on the tube to a parallel section - hopefully its within 50mm or so from the clip on......)
If clip ons are above trees, do you have 12mm of parallel below trees?
do you have a MC sorted? of so what are the CL dimensions of the mounting holes and the outside diameter of the master?
cheers
Mick
