Have you dealt with the immobiliser? I assume they are the same as Jap bikes, and have an immobiliser in the ECU. Rick?
Hello All,
I want to by-pass (remove) the ignition on a s1000rr track bike and replace it with a switch. I am trying to find a 3 pin connector so I dont have to hack the one off the OEM wiring harness.
Anyone know what type of connector it is (3 pin) and where I can find one?
If I cannot find one I will just cut the plug off the wiring harness and connect a switch directly.
cheers
john
He's already on to that Nick. They have a transponder in the key and receiver in the barrel. In the ($500) kit system, you still just use the spare service key and antenna. Which Johnny has done. He wants to get a connector to plug into the factory harness for switching, so he doesn't have to butcher the harness. If he gets it sorted, I would mind getting rid of mine as well.
Pre Modern Formula 1 Champion 2013 (GSXR750T)
www.wet4uracing.com.au Race bike & mechanical prep, fairings and parts - www.bikeshop.com.au (Protech Motorcycles)Tyres, parts and dyno tuning www.stayupright.com.au motorcycle rider training from learners through to track skills - http://worthingtonmotorcycles.com.au BMW, Honda, MV Augusta, Moto Guzzi and Aprilia
Hey Rick,
Couldn't find the connector. I think its a BMW connector.
Anyway, cut the plug off, hooked up a rocker switch and she is all go.
Biggest issue is trying to find a place to hide the antenna loop/key. I think it will fit around the ecu or under the tank (have not looked under there yet).
$16...job done.
Excellent Johnny. Thanks for the info. Will have a look after this weekend.
Hey Johnny, where did you end up putting your key/antenna?
Just up behind the cluster.
http://www.maxbmwmotorcycles.com/fic...png?v=07012015 These are all available ex BMW. They have the cheapy ones at Jay car but they are pretty nasty. Don't ask me how I know that.
Ooooh, top info, thanks Steve. I reckon it's 3/9...
https://www.maxbmwmotorcycles.com/fiche/PartsFiche.aspx You can use the part numbers from here also .From memory you drop the first two numbers or something similar and pricing is US.
Thanks man!
There are currently 7 users browsing this thread. (0 members and 7 guests)
