I searched on those terms and watched sum vids ... that fairing mount hole is part of the frame, so woodn't a TIME-SERT be more appropriate, because the NUTSERT needs to get behind something, like a rivet, and even then can't be too thick?
Depending on how thick the frame material is at that point.May only be about 3 or 4 millimetres thick which would be fine for the rivet nut .Tricky bit is probably getting the old one out without enlarging the original hole.The rivet nuts work best with a snug fit.
