Results 1 to 8 of 8
Thread: Quick action throttle
    Has any one installed a quick action throttle on a GSXR.
    Tristan
    www.aussiesportsbikegear.com.au
    0409832925
    Just use a pcv tube trick.. easy does it for less than $2
    I already have the kit it's a PP Tuning one but I just don't know what to do with the kill and start switch block.
    Tristan
    0409832925
    Cant help you there.. I dont use a quick action throttle at all..
    Tristan
    0409832925
    When I installed a Motion Pro on one of my old gixxers, I just used an angle grinder (or a dremel) to cut the throttle tube housing part off the OEM switchblock. That way I retained the OEM map switch, and it still looked factory, instead of using a cheap aftermarket switch that they told me to buy. Although I still had to fit clipons, because it wouldn't all fit on the OEM bar.
    Sweet thanks nick I'll have a look at that
    Tristan
    0409832925
    I did similar when I added my cheapy R1/6 throttle mod 1/6 turn instead of 1/4 for $12 seems like a no brainer to me
