Dived a bit deeper today removed the tank
removed airbox
removed the IACV from a spare throttle body and swapped over
IACV valve
Cleaned the K & N airfilter and gave it another oiling , put all back together and went for a quick ride . came home , took the jacket off , leaned over to put the rear stand on , only give myself a nice burn to the top of the arm from the tail pipe .. ouch...
Still the same .. with temps around the 75 deg idle not too smooth , and coughing between 1.5 to 4 k ..
so im thinking its either the lower injectors or possibly the MAP sensor which means the airbox out again ..
Havent checked the strainer in the tank yet as this would be fuel starvation which it doesnt seem to have once over the 4k and runs well above this range . Might swap out the tank with some fresh fuel too once the injectors changed .
