Hi JC,
It will absolutely 100% still work, so long as you tap the speedo signal under the tank (as you are supposed to anyway on Yamahas), like in my How To guide here: http://tarmactalk.com/forum/showthre...gear-indicator
The rest of the signal wires are still the same at the back of the dash (power, earth, rpm and neutral), so all the other inputs will work fine.
Marshy
