It wouldn't pull out with leverage, I eventually worked out the bolt's thread actually connects with the splines, so it's very tricky to cut the bolt without damaging the splines. I ended up using the dremel to cut into the aluminum gear arm so that I could remove 1/4 of the outward facing metal of the arm and then the bolt just fell out. Arm was farked ($75 for a new one), but everything else OK. I now know the inner details of the gear arm, and how it works, only another 1,000,000 pieces of the bike to go!
