I recently wired the fan switch to power direct from the battery when it is turned off.
I used the inline fuse rated at 10amp.
However turned it on and off a couple of times to test then the fuse blew.
Never had an issue when I was using a tapped "on" ignition source.
I thought the fan had a 7.5amp fuse from the factory?
Do I need a 15 amp inline or should the 10 suffice. (Not strong in knowledge in regards to this)
