Thread: How Tight is too Tight?
    I Changed the oil & filter on the R1 and it was leaking oil. (then I overtightened and fucked the filter)
    I've got a new filter on but don't want a repeat performance (or a leak). on the gixxer I just went hand tight + a 1/4 turn. is there a general rule of thumb?
    I've also put a new crush washer on the sump so it isn't that
    Lawson
    same rule of thumb with any bike.. I just go hand tight plus 1/4 turn
    fill the filter with oil and put a smear where the "O" ring seats, after you have cleaned it, then screw it on as you described, that's the way I do it and I have to use 300mm multies to undo it as they tighten up when heated
    I will re-smear tonight and get it up to temperature again, I flushed the radiatior again while I was there, but given the radiator cap is under the ram-air tube it will be a full fairing off job for scrutineering on Saturday morning.
    Thanks guys
    All of the above. Lube the o-ring! You need to work out exactly where the leak was from. It might not have been either filter or sump plug.....
    Oh, and a trick to removing the filter when doing a service (and I almost always forget this myself!) is to loosen the filter before you warm the bike up to drain the oil. It's much much much easier to loosen when cold.
    Quote Originally Posted by Negrogrande View Post
    Thanks guys
    Yep +1
    I just sent St George an email about this problem and whether we have to get scrutineered twice because the nose cone part of the fairing will be off?
    Quote Originally Posted by Mstevo View Post
    Yep +1
    Same issue with lock wire on brakes ... go scrutineering and then change wheels :0
