And in another 'Well, there's your problem" moment, check out the steering head angle on the old frame compared to the new one.
It's not a build thread yet, because it's still being un-built.....
Currently, the folding bike looks like this. If only it would stay this short, the turn-in responsiveness would be unbeatable!
Then this needs to be fitted somewhere.
So is that a newer spec frame? Say, 2014? It looks like the old one was a bit more aggressive but then again, what do I know...
Fuark... Didn't think you could push the neck that much withouth leaving some very obvious signs on the metal. It might be the first time but it seems I was wrong.
Moved it already. At some point I need to find some number/letter stamps to stamp the VIN in the new frame (they come blank, designed for you to transfer the number over).
To be honest, Ed, it took me a month to realise that the bends in the frame between the headstem and the air intake holes weren't meant to be there!! They look like a factory moulding, and they are exactly the same on both sides, further adding to the illusion. I finally checked the other bike and suddenly realised that the frame was flat at those points on the unbent bike
Thats a huge difference.
Must've been a pretty big off to bend it that much! ouch.
was this the no 1 bike Marshy?
Fortunately no, it's the No. 2, which will become the No. 1 bike because it's getting even more bling than the current one! I bought it this way (cheapish) but it's still gonna have cost an arm and a leg by the time it's finished. Which I'm hoping will be in time for next Friday.
Unless I have another one ready by then.....
I want to test and have ready a spare bike for ASBK at PI in a month.
I gather these Ape frames bend fairly easily, as the main spars are forged aluminium, joined at either end to cast alu headstock and back section, and with the engine-mount triangle hanging off below. So the lightweight spars just bend with a front impact. You can see a nasty crease in the frame at the back of the forged bit, at the back of the triangle.
