looks nice Cam.
get under it and look at workmanship. check where you wheel loads will sit and where your tie downs will attach. Also check the gvm and tare weights to make sure you can carry all you need. a 39mm axle with holden bearings is only capable of handling 750kg including weight of trailer. http://www.mullins.com.au/Pdf/Axle_H...city_Chart.pdf
if you are only running 1 bikes (around 170kg) plus spare wheels (say 15kg) plus stands, docks, gear fuel etc, (say 100 to 150kg) you would be around 350-400kg. if trailer tare weight is less than 350kg (ally should be much less) then you are sweet. 2 bikes would push the boundaries a little..
Ally will help with fuel costs. Just make sure you can get you bikes / gear / stands in and you are good to go. Price is reasonable. Plenty out there asking a lot more for a lot less...
cheers
Mick
