Check the breather on the tank . If its blocked it will starve the engine of fuel due to vaccum , fuel used not being replaced in the tank with air .If it stops again open the fuel cap and see if it makes any difference.
I just bought a '96 ZX7 with 20,000k's in immaculate condition just because I've always liked them. I took it out for it's maiden voyage today and all was good for 10km then the revs dropped and it stopped. I started it again and held full throttle which would only rev to 1500rpm. As soon as I shut the throttle it stopped again. Eventually I got home and got the trailer to pick it up and then it started and ran normally. On the second outing it did the same thing after about 10 minutes of riding. The carbs have been cleaned but it still does it. Any ideas?
Agree with Bob, Bill.
Similar to the fuel filter issue but with the air. Also listen far vacuum when you open tank. You should be able to do this in the driveway/ locally
Please forgive my lack of knowledge of all things mechanical but is the breather a tube attached to the bottom of the tank? My guru, Rick, is away for a couple of weeks so I'll have to self help on this one.
Yeah Bill. Usually a couple of them
Problem solved? I love the old ZX7, top work!
Did you blow out the hoses bill?
There are currently 7 users browsing this thread. (0 members and 7 guests)
