Not an L1 but I've done them on earlier versions. Straightforward and well worth it!
Hey has anyone done this mod on L1 Suzuki+?
oh true? I'm having difficulty figuring out if I need to dremel the housing or not.. I don't think I do because it fits and moves as it should. Only thing I think I need to do is loosen the cable at the throttle body because the only way throttle snaps back is if the adjuster is wound all the way in at the handlebar.
Here's an R6 one I did recently, scroll down to post #64.
http://tarmactalk.com/forum/showthre...e-Build!/page2
I once fucked up a quick throttle home-made jobbie.... and it was an experience I'll never forget! The throttle moved just fine in the shed, but on the first lap around, over the hill out of T5 and it got stuck WOT. Massive wheelie, massive stoppie, all while the bike is revving its nuts off at 16k rpm, and ended up running straight on into the deep gravel trap on the left of turn 6 (no longer there). The bike stayed upright, but the front wheel was buried below the axle, and it took 3 guys to drag the bike out. Scared the living shit out of me, and made me ultra careful about throttle mods! The throttle was so stuck it needed to be disassembled to release it. Be careful, is all I can say.
I use hot glue pumped into a few drill holes then shape the ramp with a dremel
Easy fix once gloves back on last thing roll wrist forward so full throttle perfect position.
Yeah.. it took me a bit but I realised that I 100% had to dremel. Also drilled a hole into my clip-ons so my right switchbox doesn't slide when I twist the throttle - only 4mm from having the grip at the end of the bar
