Engine covers! And cross enter your bike since you can also run 600s. Then focus on the clubsport but use 600s as a great way to get 'cheap' experience... if you get too tired, you can always skip the 600 race.
Ok, so I've had a squiz at MoMS and I've slowly completed the following things in prep for my first race day:
-Lockwired:
Sump Plug
Radiator Cap
Oil filler cap
Dipstick
Front brake caliper bolts
-Bought back protector
To Do:
Stick number on
Shark fin
Radiator overflow catch bottle
Water in radiator
Anything else I'm missing, particularly for an R6? I only got in one ARDC track day and I didn't get a chance to ask someone more experienced off TT to have a look over it for me.
From what I can see, I would be best entering into 600cc Clubsport (2006 R6)? D Grade? I do roughly 2.18's on full circuit.
Thanks heaps!!
yes GB makes great and very durable engine covers and literally saved my bike.. ask me how I know!
Carrera Group sells them for the cheapest you can find in Australia..
Do you not have the stock radiator reservoir?
and use distilled or demineralised water! I went tap a couple of times and they already started corroding the pipes and your water pump won't like it (tap).
wouldn't go astray to get some tank protectors for the R6's as well especially for the 06/07 models
Firstly, yes! Listen to Marshy!!
Second, Clubsport can be a 'little' more friendly but even then it will depend on those around you and your own pace... I'd focus on it 'cause your bike has a better chance of being competitive there, that's all. Since it's your first race weekend I reckon you should just make sure to get a good start/first lap and then let it go from there. If you manage to do either one of those, please teach me!!! hahaha
Haha! I used to race karts and for your first race or two, you have to start at the back. Can you opt to do that even if you qualify near the front. Would D grade be appropriate considering my times?
relax relax relaxyour going to have a ball..... Do your own thing, ask loads and loads of questions, we all only too happy to give advice
You'll start on D grade regardless... and yes, you can start at the back but why would you??
You need to lockwire your oil filter too, Mouse. If you are using a K&N, they have a hole to run lockwire through. If you are using OEM or other oil filters, the recommended way is to get a largeish hose clamp (plumbing section in Bunnings) which you tighten up around the filter, then lockwire the hose clamp to something solid. Can't remember the exact size, sorry, but it's something like 70mm?? At a pinch, you can join two clamps together, but it can be a bitch to fit both screw sections in. Better to get the right size.
Definitely cross-enter 600s and Clubsport! You get two of everything - practice session, quali, race starts (more is better, for practice), track time etc. Cheapest track time you can buy at $95 to literally double your track time! As Ed said, if you run out of energy, just skip the 600 race. Apart from a few fast boys at the front, you'll be racing against many of the same people in both classes. There's usually more of a time difference across the whole field in CS than in regular 600s, due to some guys running really old bikes and some having the latest legal models with fast engines (cough).
Shark fin is very important! Don't worry about an additional radiator overflow bottle (although i have one) - the stock one is fine. The overflow is actually supposed to go into the airbox, but it never gets checked.
Haha, cheers Stu!
So you think I've done all I need to do to the bike (other than what I've mentioned I need to do). Hate to rock up and need to have bought something else or do some mods last minute!!
IIRC, you started with the poop jokes!!
Don't you also have to lockwire the rear brake caliper with modern bikes? I also have my banjo bolts lockwired, don't we have to do them too?
Any bolt on your engine that has oil behind it needs to be lockwired as well as far as I know.
Don't do 2 classes you will be buggered.
+1,000,000
Besides, you can always sit one out if you are too tired, but you can't do the reverse and head out for some extra racing once you've realised that you are bored between rounds and want to be back out there rubbing fairings!! It's relatively soooooooo cheap to cross enter that you'd be nuts not to do it, if even just for the extra practice session and extra quali session.
Two classes, two days. Just do it. I figure what's the point of doing all these track days if when it's time to race you don't take the opportunity to do as much as you can? You'll be tired at the end of the weekend but you'd be surprised how much lining up and waiting for those lights to go out get rid of any feeling of exhaustion. Racing is the best.
Im guessing 90% of the other riders are just as tired as each other
Just thinking about those race starts gets me spinning ... fark ...
Quick tip from a race virgin, me, is to have some paper tape or something to write grid positions on, then put the tape on your tank. [there may be other ways to do this ... this was my system] When I come around T12, take a look at the position and row and line it up as you come down to the grid. Row markers are on the side of the track, but I had to be just about on the position number to see it.
I wrote on a piece of paper tape with a marker, the four (or is it five) positions across the track, with the position number in the one that was mine. I put the row number next to it. No way I could remember it for the entire warm up lap ...
ie
R10 . P38
. . _ _ _ _
. . _
Dan & James used the Natsoft system to get the position. I went for a wander / stretch up to the building near pit entry after every race to get my next grid position.
Always good to watch the races before hand to see what the lights are doing, or for anyone new to racing...
I'll be that guy! Haha. How many practice starts do you get? Where on the track do you do them?
time to practice those starts at the traffic light grand prix![]()
I watched a bloke do some at a track day, as he was waved out the gate he would rev up the marshels didnt seem to mind
The fuckup more people make than waiting for a green is going when the red comes ON. Even Graham McCarthy did this at St George in Nov. You've just built the revs, and the anticipation is killing you, you're staring sooo hard at the start lights that your eyes are popping out of your head, then a LIGHT COMES ON!!!! Hell yeah, GOOOOO!!! No, wait!! Aaaah shit, jump start.
It's really, really hard not to flinch when the light comes on. I still do it.
One thing....... once your commited to a start DO NOT EVER look away from the lights...... happened once, wont happen again....... Also if you even think you have a bike prob on the grid, WAVE like crazy, nothing worse than stalling or not moving !! If it does happen, just get small, like tuck EVERYTHING in and pray !
Here's an instructional video I made for you kids about something else you should be mindful during the start
