Should do a group buy
Next we want this
http://www.bikesportdevelopments.co.....aspx?id=37571
Nick i was almost laughing reading your opinion on the LI camera's, but thank you for sharing, you've stopped me making a purchase i might honestly regret. "you get what you pay for" I'm a believer!
Anyone else share any thoughts on GoPro verses Replay XD/Mini? I've had only good to great experience with my older GoPro's so far.
Shouldn't be, right? Even just 'saving' the button press for Record and triggering record mode when it's ready to record would work fine.
I run the gopro but currently bought a Replay XD
The go pros are good and simple to use. Good battery life and quality video.
The only thing I hate about them are the mounts and the shear bulk of them.
I always have a feeling the weight of the go pro will tear off the double sided tape mount.
The replay I bought shoots in 1080p as well as the go pro.
Battery life is less but really when races and sessions are less than 15 mins is it really relevant?
The Replay is much much smaller which I really really like!
I find that when I am braking early and not as aggressive the lever can modulate a little on the blip as it has more lever to pull, but when braking under racing conditions with the brakes under full load + a little more leaver the blip doesn't affect it as there is no more lever to pull
Don't buy from KOGAN
To be a gopro reseller you need to have a shop front, kogan get around this buy buying all there gopro's into Hong Kong and ship to a whorehouse in Aus they erase the gopro serial numbers and replace it with there own number, this voids gopro warranty and you can no longer update your gopro through the gopro website (you need to call Kogan tech)
Kogan warranty is bullshit my usb slot fell out
Kogan:What is the over all condtion of the gopro?Shippy: I have only used it twice its pretty much perfect the usb slot just fell outKogan:As the unit has suffered physical damage, we can not offer to assess this under warranty.
Kogan will not reply to any further emails
Now I know I am kinda to blame, but I wasn't rough with it...... anyways I did some googleing and it seems to be common, and gopro replace the cameras straight up when the usb slot fails
[quote name="chrispy09" post=8626]Nick i was almost laughing reading your opinion on the LI camera's, but thank you for sharing, you've stopped me making a purchase i might honestly regret. "you get what you pay for" I'm a believer!
Chubb, nice! Thanks for the reply.
I have the same thoughts and concerns about the mounts re gopro
Thanks!!!!
Sorry the quote strings didn't work. Thanks Chubb and shippy.
Took me a while......
Sunday Race #3- 600cc Modern.
Data from Harry's Lap timer overlaid with Race Render 3. Took about 2 mins to synchronise Vid #1, Vid #2 and the data with the new version
and working backwards now, here's race #2- 600cc Modern
Here's race 12 on Sunday. I attempted to make a rear view mirror style effect. I think it kind of works ok
http://youtu.be/IWCoWMVLags
You seriously need to work on your T9... losing over a sec there every lap bar one! It seems it's taking you a little too long to get the bike on its side there... and braking a bit too much as well. Again, hard to tell by just looking at the video but you can clearly see that without that corner you'd finish a good 2-3 spots ahead.
Yeh I know, as I mentioned earlier in the thread, I had close to zero engine braking, it was like pulling the clutch in with the front brakes. So T1, T2, T9 every lap was stuffed I'd bomb in with no mechanical grip at the rear, I could've cried. Every race from the exit of T12 to the exit of T2 I'd lose places/distance then make it up, lose ground again at T9, make it back up just in time to do it all again.
I really shoulda pulled the clutch out of it on Saturday night, but turns out I didn't have enough spares anyway. The main cause of the problem from what I can see was the clutch springs have sagged along with the stack height wearing down and was engaging the slipper way to easily. I think I've been abusing the clutch hard in the course of learning how to take advantage of it.
Look how glazed the plates were (bottom) and after (top)
my first time on the north circut, lots of errors lots of room for improvement
That's some nice riding!! I bet you were breathing hard after the moment with Oggy at 4:15.....
Looks fast. I'd be holding 4th into turn 10 (or turn 16, or whatever it's called now). And over the hill out of 3, I hold 3rd, saving another gear change. Good speed and lines through turn 1
Good move on the outside of 11 though... it took more balls than I'd have I reckon. Then again it might be 'cause everytime I tried something similar I got pushed out... to a point where the outside wall and I nearly high 5'ed.
Good bit of riding mate,
It's going around the outside of 10 to have the inside line to 11 which is bloody difficult.
Need to carry A LOT more corner speed than what I thought. Saw Wetty pulled that on Marshy last year and I tried it this year when I was absolutely knacked on the last club sport race.
Went around the outside of Cliffy at 10 but did not have enough corner speed to put my front wheel in front of his at 11.
I learnt from that, and now it's my favourite last-lap overtaking spot!!
Yep that's a tough one too... my problem with overtaking on the outside of T11 is that I think it's hard to gauge how fast/soon the other rider will drift out or not. That's pretty much how I've been caught out most times... thought the dude would actually make the apex at least. He didn't. I didn't. He drifted wide... I drifted to the grass.
did anyone notice how loose the bike is ?
I like loose but coming over the crest out of 3 it can get nasty. On Sunday I left it in third and just kept WOT over the crest, massive head shake so I got off it, only to find I had no front brake for turn 4 and it was to late for a second grab just coasted as deep as I could then rolled on the throttle ( I didn't know I could carry that much speed though 4 lol)
When I shift up to 4th over the crest it puts a little more weight on the front and doesn't get violent
question here
http://www.tarmactalk.com/forum/show...=9031#post9031
Well I think its been long enough Mr Marsh...Where are your video's?
Unless it's on the internet.
It's not official.
Nick I think the links broken .. I havent won anything yet
You first need to deposit $1,000 into my Western Union account, so I can pay my agent to transfer the $10,000 into your account.
