Results 1 to 8 of 8
Thread: The Pain in the Ass rear brake re-install
    Moderator Baddie's Avatar
    Glenmore Park
    352
    Hello Girls
    Seen this On the kawa site thought Id share....
    Its all about the little things to make life much better.
    "So when doing rear tire swaps usually the last thing that can screw you up is your rear brake pads being stuck together or cockeyed. Putting a tiny spring between the pads gives you one less thing to fight with."
    Not 100% shore this applies to anyone but sharing is caring.
    Attached Images Attached Images
    Moderator BoB's Avatar
    N.Beaches ,Sydney
    397
    I usually use a flat blade screwdriver and open up the pads to give the more clearance for the disc when refitting the wheel .(make sure there is some space for the fluid to go to in the reservoir ).
    Just remember to pump the brake pedal a few times to check it still works .
    Quote Originally Posted by Baddie View Post
    Clever!
    Senior Member Marty's Avatar
    Jul 2013
    Western Sydney
    401
    Damn that's a good idea! As long as it's a really pissy spring it should be fine. Why on earth don't rear calipers run two pins? On my cbr the pads always drop off the shelf on the non pin side
    Senior Member dan's Avatar
    Jun 2013
    Sydney
    1,298
    Yeah I do the same.
    Weekend Warrior CBR42's Avatar
    Sep 2013
    Croydon
    66
    On a related note i saw on someones twitter feed the other day (a WSBK rider,i cant remember who !!) has a hard spring in there to make it harder to lock up the rear brake.
    Jun 2013
    Sydney
    1,298
    Oh that's cool
    Sep 2013
    Croydon
    66
    Quote Originally Posted by CBR42 View Post
    I think I've had a dyslexic moment.i can't find the picture.it must have been a heavy duty return spring.
