Rev the bike, slip the clutch and hope it's better than the guys around you. That's the science behind my starts
Hi guys.
Just wondering if there is anyone out there that runs the Woolich racing software, and will be willing to share their setting.
I have tried a few lower rpm launch settings with different ramp speeds, but not really had the chance nor location to test all day.
This is my next map to test, thoughts?
The log data software is great btw.
Lee
Wow!! Looks impressive, Lee.
What's the symptoms/negatives of launching at the moment?
I think its lack of practice and setup opportunity.
The few I have tried started with massive wheelie (needed new undies) then went to extreme on the consecrative side, and could have jogged faster.
So it getting the correct launch rpm, ramp time, etc.
Thought that if anyone was using the software they could help out with a good setup.
So, the ramp doesn't start until 67Km/h then it does it for 1.75 seconds every shift?
Would a slightly longer hold time not help with the wheelie? Then ramp up after that speed?
Just first gear then goes back into silly mode lol
But yes a longer hold would help, but as its "steady" increase to limit, the ramp time helps keep front end down plus wheelie control.
I think you can see why I was looking for a map, or a good day of setup as there's loads of combinations, but I will work it out
Yeah, totally. I think in the absence of a friendly map, trial and error is gonna have to be the way to go..
7000 is good launch rpm. Why is your hold time 250? Ideally should be at 100. Are you slipping the clutch too much?
You want to calculate how long it takes you to get to redline from when you release the clutch. That is how long you should set your ramp to.
What is 1st gear speed based on your gearing at 7000? Ramp start speed should be just below that
Lee there a bloke on the zx10r.net site called ZX10RArcher always happy to help and theres a shitload of racers that well help as well..
http://www.zx-10r.net/
There are currently 26 users browsing this thread. (0 members and 26 guests)
