Now now play nicely boys.
Mick - dont open the cave of MPE - we all be doomed![]()
The bullshitstops when the clutch drops
Got the rear caliper mounted up, sprocket carrier all in and new spacer to suit the quick release setup.
Just waiting for the engine now...
That is a thing of beauty!!![]()
Wow.
Had a play with the 3m wrap! Not the best job, but getting the hang of it.
Great color match
Awesome job, Lee!! Well done, looks ace.![]()
Nice!! Can't wait to see it in the flesh.
What to do on a cold and wet and very windy Sunday in Canberra?
spent the morning in the hills on the dirty then after lunch when it started to rain changed the oil on the race bike and put new tyres on ready for Rd2 of FXRRC meet in a couple of weeks
Well on Saturday
Added in a Overflow bottle for the commuter while my HRC jobbie is on order
Then used an old switch I had lying around to do a manual fan override while I wait for my new handlebar switch to arrive
Looking real nice, mate. Can't wait to see the finished product!!![]()
Looks great Lee!! Very nice.
I finished off a build tonight:
ni-ice!
Needs the barracuda emoji!
Fuck yeah!! Looks fookin mint!
Up for sale then?
Looking great marshy! Love the Austin pipe, must sounds sweet.
Sorted the fairing mount issuejust need to fit the rearsets and brakes then all ready to go (sell)
Nice! How did you mount them?
Square nut inside a grommet, a washer over that to stop it pulling through then another half grommet on top and Loctite 406 the lot... It's solid🏻
Nice job! Reckon it's worth putting on rearsets, if it's going?
Ah right, yeah makes sense then..
the recent addition to the flock had woodcraft rear sets but alas it was road shift....
a day in the office today and we have addressed the issue...
hopefully get a bit more progressed tomorrow.....![]()
Nice machining!!
Farkin factory!!![]()
cheers Marshy & Sicko
riding it road pattern after riding the other bike in race pattern lasted about 1.3 laps....
For those searching this thread in the future, this mod requires taking the lower rear engine mount bolt out and inserting it from the RHS of the bike. Then a custom nut (approx. 72mm long) is made and installed with a M10x1.25 (metric Fine) thread onto the end of the bolt. The other end of the nut has a M8x1.25 thread that will allow mounting of the shift lever.
Next a custom shift lever is made, with the hole centres for the linkage end, pivot point and toe peg all on the same axis. The Pivot bush and bolt are used from the original lever (need to tap the bush out). The pivot hole is 16mm, and the linkage and toe peg threads are M6.
Finally, the shift linkage is shortened (remove the M8 LH thread end) and threaded with an M6 thread for a rod end. Ideally you want a LH threaded rose joint and taps to suit, but not a biggy if you only have RH thread as you don't adjust these very often once they are set up.
The lever arm on the gearbox is mounted upside down( steps away from the gearbox) and horizontal (instead of vertical) with the linkage mounting vertically in behind the overflow bottle.
This also works for stock rear sets.
Will post some pics tomorrow...
Wow, That's pretty involved. Good effort!!
Deff need more pics!
Will have a close look this weekend!
I hope you have better luck with your LC4 then I had with mine. Fucking nightmare.
Booyah!! Great colour![]()
Not far off now, Lee! Looking great.
Did you need to do much prep to the bumpy bits or does the vinyl mask a lot of that?
did a bit more today and got the shifter complete and went back and tidied up the prototype on the race bike....
shifter linkage arrangement
This is the hole it normally goes through ( at about 20 degrees from horizontal)
This is the configuration of the arm after installation
This is the custom nut required
this is the nut in its installed position
There are currently 10 users browsing this thread. (0 members and 10 guests)
